Brake bleed causing ABS light to activate
Australia
Anyone know why the ABS light temporarily came on while bleeding the rear brakes?
Procedure followed was ignition in On position. Son pushed the pedal, I cracked the left rear bleeder screw, stream came out, ABS light activated, pretty sure there was a ding too, closed the bleeder, son off the pedal. ABS alarm did stop straight away and hasn't come back on when driving. Brakes seems fine.
I was pretty careful to avoid getting the reservoir level too low.
Anything to worry about, or normal?
ABS light never came back on driving about. Interestingly when I bled the rears more slowly (like open close open etc etc on the bleeder) rather than one longer continuous flow there were no ABS alarms. So might just be a standard warning.
When flushing from a rear bleeder. Fluid comes out fast, provided bleeder not clogged. So fast, pressure drops faster the booster pump can keep up with. So we get a brake low pressure alarm & lights. Once bleeder closed, pressure builds and alarm goes off.
