BP-51 help
tn
Need some help from all you pros out there. Just installed BP-51 suspension on my otherwise stock LC HE. Went with 5mm preload in front and 2721 springs out back. The ride is very bouncy, seemingly more so from the rear. I currently have the front set at C1R6 and the rear at C1R4. I’m thinking I need to increase the rebound setting to slow the response after compression.
Can anyone confirm? And would also like to hear what other folks are running comp and rebound at with a similar setup.
Here’s a pic
I’m a bit surprised nobody helped you out on this. My 200 arrives tomorrow and I’ll see how it rides. If I like it, I’ll add pics of front and back settings.
Here’s a pic
With compression at 1, I would imagine its compressing with nearly no control. Crank compression to 3 or 4 and see how it feels. Then as you make further adjustments…over adjust at first (like 3 clicks) so you can more easily feel & better perceive the acceptable range of adjustment for your springs, weight and personal preference.
What I mean is… figure out where “too much dampening” kicks in…then back off from there.
