Both fuel gauges not working now
australia
New here. Hi all. Rear tank gauge hasn’t worked since we got the truck a couple of years back but we were driving some serious corrugations recently And then the front tank gauge died. Also been having some Fuel tank switch issues i. e. Switched to rear tank but taking fuel from front tank. Any advice greatly appreciated. Cheers
first, check all the wiring for broken wires. check grounds in the areas. have someone push the button on the fuel tank selector while you are underneath by the switching valve and see if you can feel/hear the valve move. could be the float is bad.
If you mention year/model that would help significantly
Thanks mate
1995 HZJ75RP 4.2L diesel 1HZ Ute that has been turned into a 6 wheel 4x4 safari truck
Thanks mate
We need some pictures of that!
