I know this has been discussed various times before, but I'd like to get the purists' perspective here...
I have a FST with no bolt holes for the hard top on the tub. I also have a hard top (non-corrugated) that's currently on the car. From my reading it sounds as if the tricky part is the windshield-top interface and that's already been done by the PO (not exactly clean, but I can revisit it later).
The problem is the top is not bolted to the tub and I think it might be good to attach it somehow.
Looks like the factory hard top models have nutserts welded to the channel on the tub. The two options that are most obvious to me are to either press in some similar nutserts, or just drill a thru-hole through the channel and capture the bolts with nuts on the bottom. And then there's the third option that's been suggested before, but seems cheesy, which is clamps. The benefit of that is that I won't have to drill holes in the tub.
How blasphemous will either of these choices be? I do want to be able to safely run the HT for now, even if I go back to a ST at some point. But I am also hesitant to start drilling.
BTW, from the attached pics, is it possible to tell what year the HT is? I am assuming those handles are not stock
I do have the original doors, but they're about 300 miles away. I can't wait to go get them. Do you think the FST doors will fit with the current setup?
