Bolt on Portals. I'm doing it! (1 Viewer)
Very nice. Are those yellow lines for your integrated air system for your tires that goes through the portal ends?
What size tires are you running? Did you do any other lift?
@BeeLikeWater Please repost along with 5 gallon bucket. 😀
Yes, I’m still getting them dialed in. I plan on doing a full write up on the kit & instal.
Are you planning on reducing the suspension lift height back down closer to stock height? It would certainly improve your up/down travel ratios.... especially in the front. OME makes some "no-lift" higher rate rear springs that might work for you.
It’s something I considered but I’m gonna run it with a lift on portals for now
Werewolf (in Ukraine, in the middle of a war mind you) provides excellent service and support--better than most companies stateside!
Looking forward to hearing more about your experience BLW.
