Wanted Boise, ID - Advanced Adapter Bellhousing SBC to H42
Boise, Idaho
  1. 55 Series
Boise, Idaho United States
I’m looking for an Advanced Adapter to mate my SBC to H42 trans.
Thank you
R.K. has an ad here for the Downey 4 speed bellhousing, better deal, stronger- - -just saying.
Thanks for the heads up! I Pmd RK.
So what makes the Downey bellhousing better and stronger?
Which flywheel, clutch and pressure plate does the Downey require.
This will be going in a 1969 FJ55 with a 1998 L31 5.7 SBC.
Thank you
Thank you
The theory is that it’s stronger because it’s a 360 degree bellhousing. Maybe. I’ve never seen either kind break. But I do know that you can’t examine your clutch, fork and TO bearing with a 360 degree bellhousing.
And the 360 bellhousing is not designed to work with a starter that bolts to the engine block (which is 99.7% of engines)
Hth
