BMAC 100-series 'build' thread
Atlanta, GA USA
Okay, this is really more of a maintain and upgrade thread than a build thread since the prior owner (and fellow member) did a beautiful job building her before he moved on up to a 200 series. The cruiser was in great shape when I picked her up in Houston in 2020 but the list is starting to get longer and the memories cloudier so trying to get a few things down here to keep track. Here she is on an early drive in the NC mountains.
And here's the list of work over the last few years (outside of routine oil change/balance tires/etc.)
Upgrade/maintainDateMileageDescription/major parts
Purchase truck
7/20
~168K
Purchased truck
Rear Brakes, Rotors
8/20
169,883
Brake disc, pads, caliper Rear Left and Right sides
Full paint correction
8/20
170,000
Dent removal, Interior detail and carpet R&R, Trim R&R, Paint correction body
Sand/repaint hood
8/20
170,100
Repaint hood in OEM paint and blend in side panels
Toyo OC AT3 Tires
9/20
170,200
4 Toyo Open Country AT3 Wheels LT295/75R16
Pioneer receiver
11/20
170,300
Pioneer NEX CarPlay touchscreen AV receiver install
PS CV boot
1/21
171,952
CV Boot Kit
Upper control arms
10/21
179,496
Install sealed Nitro upper control arms
Power steering hoses
10/21
179,496
Power steering hoses, tube assembly, pressure feed, oil reservoir to pump hose
Front brakes
3/22
183,329
New pads
CV axles Front
3/22
183,329
DS & PS CV shafts, assembly, boots, Diver shaft oil seals
Coil Assembly, Ignition
3/22
183,329
Replace all coil packs
Front Icon Shock rebuild
3/22
183,329
Remove/reinstall front Icon 2.5 shocks; ICON rebuild
New keys
4/22
184,691
Two new keys cut and programmed
Door lock actuator
11/22
198,859
Front driver side lock assembly
Brake booster/Master cylinder
11/22
198,859
Brake booster assembly with master cylinder
Wiring repair and hood struts
4/23
192,197
Find/fix parasitic drain, replace hood struts
Differential Service
4/23
192,197
Drain and refill
Timing belt replacment
4/23
192,197
Timing belt kit, water pump, cam and crank shaft seals, thermostat, drive belt
Brakes and Rotors - Rear
4/23
192,197
Brake disc, pads, calipers R&L rear
AC System Charge
4/23
192,197
Good old R134A, nothing obvious in leak test
Throttle Body
5/24
197,083
Cleaned… idle so smooth now
Icon Recon SLX Wheels
8/24
198,751
5 new Icon SLX Charcoal 17” wheels w/ lug nuts and DeltaV cap spacers
New 34” tires x 5
8/24
198,751
Mount 5x LT285/75R17 Toyo Open Country RT Trail
Rear axle seals
8/24
198,894
Right / Left axle seals, Diff fluid
Power Steering
8/24
198,894
New rack and tie ends, oil filter and cooler seals, align
Forgot until I just saw an update from reznunt about having a hidden console vault in stock that I also had fun welding one of those into the truck a few years ago.
