Not sure about that sorry.thought process that it had to be manually reset.
Did the motor spin freely by hand?. Does it have bearings or brass bushes?I know those porous brass bushes dry out. You can soak them in oil for a while to relube them.
It did, yes. When I took it apart, it was filthy. The brushes are in decent condition, but I cleaned the windings and it everything back together. I can't imagine it's the motor, since I directly hooked it to the battery and ran fine, and with more speed.Not sure about that sorry.
Assuming the switch is working correctly, when the fan is on high the resistor assembly should stay cool, as the power to the fan bypasses the resistor completely. I've been chasing some gremlins in my front blower motor circuit while waiting for new diodes for my gauge regulator project and recently been digging into the workings of the circuit. It's a very weird design.The only other thing I can think of is to pull out the resistor panel, keep it wired up, put the blower on high and see if any of the resistor springs get hot.
Thanks G-man, yeah, AC blue light does not go on. I ordered more stuff from RockAuto today, new resistor & relay and a CB from Sunnyside Toyota (Toyota Parts Barn)...one of my go to's , was surprised that the CB was available new OEM cause I had a really hard time finding a part number (#82650-20011)......I don't think the heater resistor comes into play with the fan on H. It is used to neck down current in the lower settings.
you could try replacing the heater CB with an inline fuse. It's a known issue. Usually when a heater CB loses it's resistance it will trip the breaker too when the AC is on and the fan on high. Pulling the CB out and resetting it by pushing a finishing nail in the hole will reset it, But they lose strength when the get old. Mine was tripping at about 14amps when it is supposed to be a 30a breaker. If you push the AC button in and don't see the blue light come on, then your heater CB is tripped. Here's an image of what to do using an 30 amp inline fuse:
