Blacked-out bumpers (more de-blinging)
Is this stuff OK?
Your dangerous with a 100...period :flipoff2:
I do have a few things if like to play with. Plasti-dip is a great thing if your not serious about it. Im not, but want to see how it looks.
I will not deny that! Lets see that fxr...
I need 06-07 headlights for these suckers. It will come sometime in January. I will re-define the meaning of low beam. It's the only pair in existence so I want to make sure I get it perfect. It will take a few days per headlight.
Goodjob mr. TRS! Are you going to do the 06 conversion as well? Or just cram them into the ones you have now
I wouldn't even try with the older headlights. A 2.5" FX-R cant fit inside. I was set on a LS460 low/high beam but I may switch it up. Ultimately I want the projector shown above for a Low/High bi-xenon, and the LS460 high beam projector paired with 70W Ballast. All OEM hopefully. I'm going to attempt a internal ballast on the Depo's. This won't be cheap...but I won't need a LED light bar, hid offroad lights, etc
Working at TRS has its perks. You guys always get the good stuff...Did you find the depo 06-look-a-likes? I have been searching for another set but I believe they are discontinued:bang:
I haven't found a set other than the ones for 200 per light. Where did you get yours?
Bought them on this site yourhotcar.com of something like that a while back...but they used to be on fleabay for $160 per pair
The ones $200: Do they have the orange side marker lens? The depos are clear all the way thru. That is how to make sure they are the depo
