Oh, <laughing> I thought it was a parts supply house... Would be a great name though... Mudder's LandCruiser Parts, Inc. What makes these switches work sporadically? My reverse lights work some days and not others... Seems gummed up...A member of the ih8mud forum.......You for example.
Wow, that's just scary... Too similar! The force is with you Luke, replace your neutral safety switch before the dark side consumes you!View attachment 950704 Put on a bath robe and pick up a light saber and you would look a lot like this guy.![]()
Or this guy...View attachment 950704 Put on a bath robe and pick up a light saber and you would look a lot like this guy.![]()
I would check the connections .... my 80 had a sporatic issue like that and once I clened the connections (and added dielectric grease), all was good.Oh, <laughing> I thought it was a parts supply house... Would be a great name though... Mudder's LandCruiser Parts, Inc. What makes these switches work sporadically? My reverse lights work some days and not others... Seems gummed up...
You know it had crossed my mind to check that... I'm sure I've been in water deeper than that electrical pigtail connection. Definitely worth checking first... Great suggestion!I would check the connections .... my 80 had a sporatic issue like that and once I clened the connections (and added dielectric grease), all was good.
Great post! I will crack my NS switch open and have a look-see. One would think they'd have made the switch either waterproof and sealed or out of non-corrosive materials. Thanks for the tips! Posts like yours make this site invaluable...I have repaired the Neutral saftey switch in my HDJ81, and am about to so same in my BJ74. And yes water is the culprit. On the HDJ81 even the lights in the display N L2 D R etc were intermittent. I was lucky in that the NS switch came off the shaft easily and opened up nicely. The contacts are brass or copper and were not corroded. The problem was the little springs in behind the contact that force them onto the contact sliders. These springs are less than half the diameter of a ball point pen spring, and only a few mm long. They are made of material that corrodes ! So there was no pressure on the contacts. I ended up making new springs by re winding ball point springs into the length and diameter needed ( Painful little process , but beats paying x hundred $ for new Neutral S. switch) I also loaded up the enclosure with dielectric grease in hopes of keeping the water out. I would imagine if you can get your hands on a N.S. switch off any auto vehicle, you would find such springs. I will need to to take apart the BJ74 N.S switch soon, as I am tired of reversing with one foot on break pedal to see behind !.
will do. Where do you get the dielectric grease? Home Depot?The corrosion I had on my 80 was in the connector from the pigtail to the main wiring harness. Look there as well.
Question for you. My neutral safety switch looks pretty nice and new on the outside, but the flexible conduit runs up on top of the trany and disappears with no modular connector in sight (even with a mirror). I'm wondering if the pigtail connector is accessed from inside the vehicle under the automatic shifter box?I have repaired the Neutral saftey switch in my HDJ81, and am about to so same in my BJ74. And yes water is the culprit. On the HDJ81 even the lights in the display N L2 D R etc were intermittent. I was lucky in that the NS switch came off the shaft easily and opened up nicely. The contacts are brass or copper and were not corroded. The problem was the little springs in behind the contact that force them onto the contact sliders. These springs are less than half the diameter of a ball point pen spring, and only a few mm long. They are made of material that corrodes ! So there was no pressure on the contacts. I ended up making new springs by re winding ball point springs into the length and diameter needed ( Painful little process , but beats paying x hundred $ for new Neutral S. switch) I also loaded up the enclosure with dielectric grease in hopes of keeping the water out. I would imagine if you can get your hands on a N.S. switch off any auto vehicle, you would find such springs. I will need to to take apart the BJ74 N.S switch soon, as I am tired of reversing with one foot on break pedal to see behind !.
It's got to be under the shifter box on top of the trany, there's no way a human hand could fit up there...It had a fairly long lead but it does not enter the cab. It's up there someplace. I wish I could tell you more than that. Mine's a 5 speed so I can't go look....
