ug. Bad timing for this….was flushing my coolant system and as I started refilling it I discovered rear heater hard lines had corroded through…Bugger! Looks like I'll be doing a soft line splice, by pass, or rear heater ectomy...
Rob:
I removed my rear heater lines as well as the rear heater and plugged the floor with OEM plugs.
... I discovered rear heater hard lines had corroded through…
from the plumbing section at my local hardware store….some sort of test/inspection plug….
