Hi all, update
I received and mounted the mastervac and the brake calipers , but the brake pedal is always very hard ....
but I noticed that the suction coming directly from the tube of the vacuum pump without going through the vacuum reserve is higher than what I hear in the tube coming from the tank itself
could this be the cause of the problem?
can I connect the tube from the vacuum pump directly to the mastervac?
thank you
Giacomo
yes, you can connect the hose directly from the vacuum pump to the brakebooster.
Then, first and maybe second time you pres your foot down the pedal will be ok and the brakes will work. But third time it will be hard. Wait 4 seconds and it will work again.
Have been running my bj42 like that for years, never got around to mount the vacuum tank
