Bilstein 6112/5160 Installed (2 Viewers)
Thanks, I love it and we got hammered in Colorado with snow this week. 31 inches at my house the LC was perfect out and about driving around. I didn’t install it, but they said the front went up 2.2 inches. I think that’s perch 3 because I had 2.6 and 3 left to go. I only went up an inch in the back. Rides great.
Which rear spring did you use?
Exactly my reaction to what I currently have, @ryanCA.
So to achieve the back to front rake you have, did you install rear springs or spring spacer? I guess the idea is just to raise it an equal amount all around in order to achieve factory rake at any height.
no spacer
mine has bilstein rear springs
Hey All
Thanks for such a valuable thread with great info. Looks like this will be the combo i choose soon for the Egg
Questions... UCAs? How many of yall are running the STOCK OEM UCAs?
I am looking for 2-2.25' lift in front and likely 4th clip.
My truck has 212k and all stock everything, so i am replacing ALL of my control arms, links, etc...
Im the oddity when it comes to stuff like this and would prefer a brand new OEM UCA than an aftermarket one, if possible.
I much prefer longevity over an extra inch or so of travel, as long as i can align it properly and wont damage anything.
Thoughts?
Thanks
Hey All
Thoughts?
Thanks
most of us running stock oem uca
280 k miles here with perfect alignment
my days of needing the extra inch are long gone
Awesome! That’s what I was hoping to hear!
Thanks
@sdnative was kind enough to meetup today and let me check out his rig.
His is literally exactly what I’m thinking of doing.
Thanks
Just picked up my ‘19
after getting the 6112/5160s installed as well as SPC UCAs. I went with perch 4 and the standard rear Bilstein springs. Very pleased with how it turned out and the ride is both more comfortable as well as more controlled.
Pulled the trigger on a front only set. My hub center to fender ride height is 19” front/21” rear, and that is with the Toyota spacer installed up front. Between winch/bumper/supercharger/group 31 and second battery up front I figure I’ve got 240lbs extra on the front wheels. I’m going for perch 3, keeping the spacer and hoping for about 1/2 of rake.
Had the bilsteins on my LX for 4,500 miles now and loving every minute of it. Just swapped out the normal rate bilstein rear springs for the HD ones this weekend. Front on perch 4. Sitting at 22 1/8" up front and 23 3/8" in the rear. Pretty level side to side. I did use a OME UCA to dial in more caster as the steering feel wasn't where I wanted it. I also have a 15mm coil spacer in the rear on the drivers side.
How is everyone liking these on Fireroads?
loving it
get better orgasm from my Bilsteins than my mistress
must have on any200
Seems time to find a new Mistress
Drove about 150 miles on the Bilsteins. No more nose dive on braking. Excellent handling dynamics. Lot firmer turn in not wallowy.
Feels like went from Lexus LS to Lexus IS.
Really happy with it.
Perch 4
Stock UCA - aligned excellent
22” front
22.5” Rear
SOME BEFORE AND AFTER PICS
Man this looks really good! Perfect proportions if you ask me. As Goldilocks would say, just right… 👌🏼
Looks great.
I've thought about doing the swap for the HD springs. Is the part number 53-292018?
