BFG KO'3s on 100 series - optimal psi?
Recently got set of set of new KO'3s on 16" wheels. Discount tires had them at 50 psi. Is that too high? Wondering if that's contributing to slightly harsher ride compared to my Nitto Ridge Grapplers which I replaced with. What's the optimal pressure for daily driver mostly on road with summer coming up?
Optimal pressure depends on the size, load rating and load. 50 is most likely way too high. If you have stock size, set them to the pressure stated on the door jamb. If they're not stock size or the load rating is far off from stock, do a chalk test.
  • Like
Reactions: GTV
