Betty White Refresh (1 Viewer)
Now's the time to run wires for future use. Extra lights, inverter, etc. Don't forget to wire in a back-up cameras while you have it all pulled out.
Also - CB/HAM antenna cables. Whichever you plan. Now's also the time to put in new speakers in the back over head cargo area.
Also - is you rig wired for towing? Nows the time to do it, and do it right.
Antennae, reverse lights, backup camera are all things I would have forgotten. Thank you! It is wired for towing but the green wire that runs along the far back has been cut. . . What would that be for? All lights functioned that I know of on the rig. Never plugged anything into tow harness to check it though.
I have the green wire also, and have no idea what it's for. I did the trailer, and e-brake wiring myself.
Don't forget also sometime in the future you may want to add LED work lights on a rack in the rear. I'd recommend a Power Distribution Block for future wiring. Bring a 0 or 4 gauge wire direct from the battery (or 2nd battery). You can tap into this for power needs (life a fridge). I have two behind the right side cargo panel (were the 8" woofer is). Makes it easy for power needs. Just be sure and add a fuse at the battery side. This is what I ran for my amp and block... Boss Audio KIT2 8 Gauge Amplifier Installation Kit
Nice to run all the wires while the carpets out!
Also -- the cubby hole on the right side is a great place for a rear subwoofer amplifier. A small mono block fits in the easily.
This is the one I'm using for the rear/right sub -- SOUND STORM SMCM200 Mini 200-Watt Monoblock, Class A/B 2 to 8 Ohm Stable Monoblock Amplifier - but any compact amp will work.
Don't forget to replace those cargo overhead speakers with something better!
Who would have thought a Prius could handle an Inline 6!
Looks like you are going to be busy - enjoy!
:popcorn:
With the rear seats out did you do the fuel pump sock, etc?
Can't believe you left the old busted s/w in the picture with all that fresh dynamat. :flipoff2:
Awesome work!!
