Best way to clean speaker grill
Does anyone have a hack or product to clean stubborn dirt/markings on factory speaker grill? Also scuff marks on the door vinyl panels, etc..
Folex Instant Carpet Spot Remover
Magic Eraser for the plastic trim, do not use on any glossy surfaces or nav screens as it could leave tiny scratches.
Got the Chemical Guys' Super Cleaner spray, it works pretty good.
Just replace them... buy the speaker mesh on amazon and re-wrap them. Takes approx 5-10 minutes to remove each door panel. Plenty of members have done this and looks great when done.
I've had every door panel off multiple times but be aware that you can easily introduce squeaks if they have never been off before, or if you don't get everythng back just right. I've had to since take mine back off and add felt tape to contact spots to eliminate squeaks and rattles.
Some owners have also just tossed the mesh and painted the plastic grille underneath once the door cards are removed, I think it looks pretty good that way too.
Yes, my right door has started to intermittently squeak, sounds like it is coming from the door handle grip. I'm getting door speakers replaced this weekend, I'll be sure they put it back correctly.
That one is usually the main bolt down under the window switches wasn't tightened properly, but it can also be plastic connectors rubbing, which I wrapped with the felt tape as well. Sometimes the metal lip at the top of the door that the whole card hangs from gets squeaky too and you can line the whole piece with the same tape.
