Any threads/youtubes on how to do that? This is the first vehicle I've had interest in modifying so I'm learning still.I'd be less concerned about air intake than maybe extending your diff breathers, making sure your xfer/trans breathers are goodntight and prepping your fan so it doesn't torpedo your radiator when/if it hits water.
Make sure you don't cut too much of the passenger side fender liner. I extend my intake using 4" to 3.5" silicone elbow and some plastic pipe to pickup at the rear of the fender.
Don't have equipment to measure it. But my calibrated right foot did not notice any differenceDid you measure airflow before and after? I'm curious how this affects the intake.
Don't have equipment to measure it. But my calibrated right foot did not notice any difference![]()
At low RPM it would be zero difference. It's AT full WOT 5000-6500 RPM where it might cause some issues.If you have Techstream or any OBD app you could look at the MAF level at Idle before and after. Would give you a good idea if it's able to get the same amount of air in as easily as before.
Also - do you happen to have any pics of your install? I'm interested in trying this
Resurrecting this one from the dead... How long was the poster tube? I've picked up a couple 12" sections of 3.5" tubing, and they seem really short. Even found oa CARBON FIBER one! hahahaAt low RPM it would be zero difference. It's AT full WOT 5000-6500 RPM where it might cause some issues.
This is how Brian S did his
Picture of the area behind fender. I think I stole this picture from Kichiro Prado conversion
This is how mine is during mock up. I end up not using the clamp. It's tight enough to the fender that the elbow would not move.
The tube I got was 24" I have to cut 3 it down quite a bit. Maybe 16-18". Sorry did not really measure it.! Resurrecting this one from the dead... How long was the poster tube? I've picked up a couple 12" sections of 3.5" tubing, and they seem really short. Even found oa CARBON FIBER one! hahaha
Bringing this back to life again! How has this been working now that you had been running it for a while? Any issues? Anything you would do differently?The tube I got was 24" I have to cut 3 it down quite a bit. Maybe 16-18". Sorry did not really measure it.
Haven't got the need to go deep and I still run fully intact fender liner even with 35x10.50 tires. Hopefully never have to go deep. There are a lot of other stuff that would get damaged if water get inside the vehicle.Bringing this back to life again! How has this been working now that you had been running it for a while? Any issues? Anything you would do differently?
I'm with you on that! No desire to go deep but I will have to trim the fender liner a bit and just wanted to do this as a preventative since I don't want a snorkel. No issues with airflow at all?Haven't got the need to go deep and I still run fully intact fender liner even with 35x10.50 tires. Hopefully never have to go deep. There are a lot of other stuff that would get damaged if water get inside the vehicle.
I am pretty sure it would be much more protected than OEM.
Not that I can tell. Very very seldom I run this engine at high RPM and I cannot tell the difference anyway.I'm with you on that! No desire to go deep but I will have to trim the fender liner a bit and just wanted to do this as a preventative since I don't want a snorkel. No issues with airflow at all?
