Are the rubber dampers on the disc less reliable/strong/longevity than the spring design like those pictured above in the Marlin Kit? It seems Marlin's is a reputable company and I assume their clutch would be of good quality.
Would also like to hear opinions on the centerforce clutches...
No, the rubber dampers are far better. They do not fail. The steel springs will fatigue over time (esp. w/ heavy use), then they shatter and the shards of spring are slung outwards into the workings of the PP.
Again, not an opinion, just a statistic. Never seen a rubber damped disc fail on any stock vehicle, seen plenty of sprung hubs fail, shedding the springs which lock the release fingers on the diaphragm.Interesting take on the rubber dampers vs the spring ones. Anyone else have an opinion of this? Has anyone ever experienced a spring failing?
Maybe a little, but it doesn't seem to effect function.Wouldn't the rubber harden and crack over time?
Good to know. Learn something new everyday! I was thinking of ordering one because I have heard good things about the company but that information helped me understand that it is not worth the extra coin! ThanksSorry, no opinion.
Centerforce clutches are CF assisted, so the harder they are revved, the tighter they grip. Behind a turbocharged engine, or a staged nitrous system they are ideal, because as the RPM climbs, the crankshaft tork climbs and the clamping force climbs. A 2F makes peak torque at 2000RPM, while theCF assist doesn't do much until higher RPM.
