@Broski , I did do my homework.
@Box Rocket has document this, which is why I’m moving the axle forward the same way he did. He specifically mentioned, “These will give better tire clearance at the firewall.”
He documents moving the axle forward in his build thread in post #674.
Looks good but man it's crazy how even 37's look small/normal on these
forum.ih8mud.com
Adam also documented his DIY bracket on expedition portal on post #541.
“After the bumpstops are sorted, the last step will be to relocate the front axle ~1.5" forward. I plan to do this using the method Darren McRae has been using in Australia for some time now with the Slinky kits and factory radius arms. New plates are welded in to the frame bracket for the radius arms and new holes drilled farther forward. These will give better tire clearance at the firewall. Don't want to move it to far or there are clearance issues with the front panhard.Rocket
After the bumpstops are sorted, the last step will be to relocate the front axle ~1.5" forward. I plan to do this using the method Darren McRae has been using in Australia for some time now with the Slinky kits and factory radius arms. New plates are welded in to the frame bracket for the...
www.expeditionportal.com
I’m using the @eimkeith bracket, who also has documented the need to move the axle forward. says, “The other aspect that I was interested in was relocating the axle forward to create more firewall clearance for larger tire sizes.”
FJ80 / FZJ80 RAM
Did you “need” to move the axle forward? No. But it will help according to these two knowledgeable members.
