Bent rear lower shock mount
Hiluxforever
Johnstown, CO
My lower shkck mount is bent and I was unable to mount a new shock.
Not sure what I am going to do, yet. I futzed with it for about 90 minutes.
With KDSS over ridden its unsafe to drive. But with KDSS engaged it can be gently driven without too many issues. So I can limp it around until I can get a new mount welded on.
I bought a logging chain and am going to try a trick with it and a jack to try to bend it back.
I didn't like how it was flexing the jack so I stopped messing with it.
Is just the post bent? It looks fairly straight. Or is the whole mount bent?
Assuming the mount itself is not bent, it can be really hard to install the shock with the rig on the ground. The angle of the lower shock mount does not mesh very well with installing/removing the shock. It's a lot easier if the rig is up in the air with the suspension at full droop and the wheel is removed. If the shock is installed loosely from the top mount, you should be able to get it on the lower mount by lubricating the post and then whacking the shock on the metal portion of the lower bushing with a big hammer (like a dead blow hammer). Once it starts going, it should slight right on.
If the whole mount is bent....you might need to have your old mount cut off and a mount from a junkyard axle welded on. Otherwise, it would need to be heated with a torch and bent back into shape.
The mount is crumpled and twisted up about 45 degrees. Enough that the axle housing itself prevent installation of a shock on the lower mount. I came down so hard it was spine jarring so that must have been when that happened.
It will need to be cut off and a new mount welded on. There are signs that the re-enforcement welds are cracked.
I am an engineer, self made, not college educated. So had to work twice as hard to get there.
Got it.
I still have my old 8" housing laying around, but it's destined for the scrap yard. I'd be happy to slice off DS end of the axle tube (with the shock mount and panhard bar mount intact and attached) and send it your way for the cost of shipping and a few extra bucks. I am 99% sure it is exactly the same as the 8.2 housing since the 8.2 and all accessories (shocks, panhard bar, brake line brackets, etc.) bolted right over from my old 8" housing.
Thanks for the offer.
I am going to talk with a couple local fabricators about doing something to beef the mount up to prevent it from happening again.
I was only going 2 or 3 mph when it happened. I slipped off a rock and dropped maybe a foot onto the shock mount.
I had hoped it was a place where my skids were bent but this damage is kore in line with what I felt.
I chalk it up to the price of playing. I
eimkeith makes a kit as well:
I have the kit sitting on my workbench and have not yet gotten around to installing it. Probably next year when I add other skids to the rig.
I have the kit sitting on my workbench and have not yet gotten around to installing it. Probably next year when I add other skids tot eh rigs.
This is another option although it has a different purpose
I'm just spit wading here, but from what I can see in your photos, is it possible to get a length of steel tubing, with the inside diameter as close as possible as the outside diameter of the shocks shaft? You should than have the leverage to bend it back in place, unless you're needing to bend it upward, into the frame, hence you wouldn't have much room to leverage.
Looks like it has a pretty big crease in it. It would not be a bad job to weld one on. Care would need to be taken to cut them in the same place, bevel the edges, and then put a gusset across the weld in a few locations to reinforce it (as it can't be welded from the inside).
I used all jack and chain and put about 5-6k lbs of force on it and it just smiles at me. No way to get anything more than about 2 feet on it.
  • Wow
Reactions: r2m
Have a quote from one shop for HD lower shock mounts waiting for the second estimate.
Doing lower profile HD shock mounts. Johns 4x4 in Loveland/Johnstown is doing the work. Hoping this is a one and done.
Truck is going in Monday for the new shock mounts. I had to commute with it to Cheyenne for 5 days. I also did Yankee hill with it, and it was unstoppable. Did all the hard lines. Next day we did old flowers road.
I have the replacement 5100 for it already, so should be golden by Tueaday afternoon. My work is cool so I can do work from home for both days.
Things have not gone as hoped. I will probably be picking up an unfixed truck and a refund tomorrow. No ill will. These thjngs happen. After all I am the one that broke it.
Call a junk yard. I bet you can get that cut off and shipped to you. Tons of rolled gx’s on ebay that won’t be needing those shock mounts anymore.
Did they try to bend it? Seems like welding a new one on would be the best route. Bending is just going to leave it as a weak spot I would think and it sounds like you’re wheeling a little spicey if you bent the first one on the trail : )
