behind the headliner
does anyone have pics of the ceiling of their rig with the headliner removed? Mostly interested in the roof rib back by the rear hatch.
Thanks
I have pics of the headliner removed but I don’t think I have any of that area. Think I was standing at the gate when I took the pic's, what specific detail are you looking for?
Unfortunately I am not in the same state as my main computer (the one with the pics on it) and when I get back it is still dead (still waiting on Epox to fix my MoBo)
I put a couple up showing the rivnut in the back from the inside. Might help?
I am looking for the last roof rib that Dan talked about, the one with the flat spot to mount the light.
E999 I will look through your posts tonight in hopes,
Thanks you two, the write up you two did earlyer about the roof racks really came in helpful to me when I tackled mine.
This a quote from Dan
[There is a dome lamp wire pair bundled in the rear roof wire that goes up the LH pillar. It is folded up and taped to the harness and is right in the uppermost rear corner. When cut free it reaches not quite halfway across the rear sill. An inspection of the rear sill leads me to believe that the OEM lamp is to the left-of-center of the vehicle. There is a flat surface in that spot but it is not relief-cut to mount the lamp (in a US model anyway).]
D-
it is in this thread
https://forum.ih8mud.com/showthread.php?t=28622
Refuge instaled a light in the back of his, his is like the others in the truck, my rear light is much smaller. Refuge do you have time to elaberate on your work. Did you have to cut the flat suface to make room for the back of the light housing? Did you run into any problems with the headliner? Is the back of the larger light flat. My smaller one has stuff on the back so the flat spot needs to be cut to fit flat, if yours is the same how did you make yours work?
Well thanks everyone.
Steven
