BBRC For Sale / Wanted Thread (2 Viewers)
Anyone have a set of old running boards for a Fzj80? Trying to put some back on this 80
I have a set that I was about to throw out
If you smear a ditch your drum brake 40, here’s a cheap option for ya. Small knuckle pattern knuckles out - no calipers includes rusty birf and warn hubs $100 - located in harrisonburg At least one knuckle stud is stripped You’ll need to check them out and helical or weld em
What does this go to? I'm assuming a 40
40, 42, 45, 47 or it could go on a minitruck or 60 axle, but you're moving to a small knuckle pattern. I ran small kuckles on my sprung over 55 for years and they held up but when you want to go highsteer, large knuckle pattern is pretty much the only thing available. I've only had this 40 for a year, but the one knuckle stud wouldn't tighten down prior to wheeling down at Relic Run. Check your knuckle studs folks! I am working on putting the knuckles from a 62 onto this 40 axle.
15 x 7 wheels off early 80. Should be the same as mini truck. $100. Tires are no good. Complete with center caps.
  • Back
