- Vehicle Model
- 80 Series
White Knuckle Toyota 80 Series Land Cruiser / Lexus LX450 Rock Sliders - $350
This sliders cat protection has been modified to work this downpipe for more clearance:This is the ideal setup if you’re looking to rotate your catalytic converter for better clearance under the rig. I’m selling a MagnaFlow California Grade CARB-Compliant Direct-Fit Catalytic Converter (Part #447103) with CARB Executive Order D-193-103. It’s been used for 20,000 miles and was ceramic coated for added durability.
Retails for $850 before coating—letting it go for $400.
"MagnaFlow California Grade CARB Compliant Direct-Fit Catalytic Converter 447103 helps keep the check engine light off. DIY installation is easy with the proper tools (no cutting or welding required). With features including mandrel-bent tubing to eliminate flow restrictions and stainless steel construction to resist corrosion, you can have confidence in the quality of this catalytic converter."
These parts are used and proudly wear their battle scars—perfect for instant street cred at the mall. Give them a fresh powder coat if you're feeling fancy, or just bolt 'em on and head straight for the trail.
Sold items below:
4X4 Labs Rear Bumper w/dual swing outs, tire and ladder attachments - 80 Series/LX450 - $1500 - SOLD
Cruisin Off Road Transmission and Transfer Case Skid Plates - $200 - SOLD
ARB Bumper - Winch Bar - 80 Series/LX450 - $100 - SOLD
