Battery under seat dangerous? (1 Viewer)
Smithfield, VA
I've been trying to decide where to mount a second battery in my 73 and was close to a mount under the drivers seat but a couple friends acted like this was a very bad idea... I have seen several setups on here with people mounting under the seat... Any bad stories from an install like this or is it relatively safe? I am still running a poly tank under the passenger seat and have Corbeau SS baja seats with clearance to fit my second battery... Opinions appreciated...
100 000 - million dollar caterpillar bulldozers and front end loaders had there battery's under the seat for 50 years with out any problems aside from the seat trying to chop your head off when you lift the 100lbs battery's in and out .
i would suggest using a sealed battery , preferably a optima then you can mount it sideways so it will sit under the seat better .
just protect the positive terminal so nothing can accidentally arc on it .
you could also get a a battery case , the plastic ones for rv's are pretty cheap and work well . there are of course fancier aluminum ones on the market .
make sure you bolt it down good .
hot rodder's generally have there battery's inside the cabs with out any problems .
it can definitely be done the right and the wrong way .
the reason why i say to use a sealed battery is because when non-sealed battery's are charging they give off hydrogen gas , and you could possibly spill acid ruining your shoes .
x2 on the sealed battery and bat case. also i would make sure that your +cable is tucked out of the way.
Ford vans in the UK put the battery under the seat. Not the best idea but OK.
Neat touch, not applicable to you, is a short section of copper bar in the engine bay which is connected to the +ve terminal for jump starting (coved with plastic shroud for safety).
Many older VWs had them under the driver's seat, the '78 412 wagon I had was there.
Seems like a logical question, why not use some fine, unused space.......Convenience and safety would be my concerns. Probably would never have an occasion that would hurt you. Just remember, though, you already have the gas tank inside the car with you. Properly vented with sound hosing, it shouldn't leak fumes or liquid......but.
Batteries were also inside cars in the old days--VW bugs had them under the rear seat, Land Rovers under the left front seat, still do in Defenders. Older vent-style batteries could and would give off sulfuric acid fumes into the cabin. Land Rover uses some vent caps and routed vents in an enclosed under-seat box with lid. And trying to either jump-start yourself, or help out someone else with a dead battery is a royal pain without some type of remote hook-up, depending on how you wire things. Sealed AGM batteries supposedly don't outgas........but there's a vent relief on them for a reason--the manufacturer knows that pressure and gas build-up has to go somewhere if excessive. Ever forgotten and left an Optima on a standard charger too long?
All this is fine and good with the vehicle in the correct upright position. However, should you get into a wreck, and you and your passengers be pinned-in, and the truck be overturned, gasoline dripping out of places and battery cables laying in the wrong places and........
Sure it's rare, what's the chances, are you a gamblin' man? What was it Clint said, "Well, Punk, you have to be thinkin' to yourself about now, do I feel lucky?" At least before you add in your battery, think about it. Lots of folks have stuffed two batteries into the engine compartment by being creative and moving other things around. That's my first choice. Anyway, my two cents.
gas
[FONT=Arial,Helvetica]3. Do OPTIMA batteries ever produce gas?[/FONT] [FONT=Arial,Helvetica][SIZE=-1]When used with a properly regulated constant voltage charging system (such as an alternator), the OPTIMA battery will normally not produce hydrogen gas. Occasional gassing can occur when charging at higher voltage levels or in extreme high temperature conditions. In automotive applications this typically will not happen if the alternator/regulator stays below 15 volts.[/SIZE][/FONT]
I was thinking of gas from charging but here is what Optima says
If you are going to put it under your seat your should put it in an enclosure. You should also use a vented battery that you can vent outside of the cab. Good luck.
