posting this for don aka fc187. please don't pm him because he's hardly ever on the computer so he won't get back to you anytime soon..........
here's the run down:
top cut off, bobbed rear 12" ( looks oem )
soa on 60 series cruiser axles
front axle is cnt, has bullet proof steering stops and custom gussets for the housing and knuckles riding on fj55 rear springs on custom mounts and shackles
rear axle is soa, welded diff, custom track-bar bracket, custom sway-bar that started as a currie anti-rock bar, riding on 63" chevies also ruffstuff HD diff cover
all new ruffstuff perches, u-bolts and u-bolt plates
37" MTRs on 15x8 rock crawl;er steelies with 2" back spacing
454 engine that's supposed to be good used but we did'nt know the seller so it might need an overhaul. we'll call it a good core so as to not over-advertise it but it is complete
custom fcfab engine mounts
good th400 transmission
good 203 range box
split case
all mounted on a custom fcfab skid plate/x-member.trans mount with track bar mount
fj60 brake master and booster relocated slightly to the driver side to make room for the BBC ( looks oem as well )
and lots, lots more. all custom work was done by don aka FCFabrication. he's moving onto other things so the piggie needs a new home. if he can't sell it within 10 days then it's getting parted out and that would be a crying shame.
you can see some of the build-up pics here but there's a lot of progress that has'nt been documented on the thread. i can post pics but it'll be in a week. i'm leaving very early tomorrow morning for the roundup in TX and won't be near a pc for a week.....
finally building my 55! - Pirate4x4.Com Bulletin Board
here's the bottom line. the rig rolls but does'nt drive yet. it needs some ebgine work, plumbing and wiring. price is $3k VERY FIRM and you know that's a smokin deal.
located at our shop in stockton CA right off hwy99.
enough said.
good 203 range box
split case
enough said.
