I only overheat when at highway speed‘s past 10 mile drives but when I stop at a stoplight the temperature comes back down. I thought I might not be getting enough circulation through the cooling system so I set up a hose to check flow. If I’m flowing this much water with the engine off is it possible my water pump impeller is spinning freely so when the engine is running it’s not flowing water under pressure? I did remove thermostat for this test.
