1981 2H
My glow plugs aren't working. ... My light stopped working a month or so ago..........., I hear the realy working.......... a way to test the power going to the plugs. Could someone explain this procedure to me (with pics). Explain it as though I don't know anything.
OK Greg. I'll have a go:------
Your battery provides the pressure (called "voltage") that forces current to flow through your lights, horn, wiper motor, glow plugs, etc.-- when you switch them on. It is this current flow that makes them work. Electrical people give these motors, lights and heaters a general name called "loads".
By "switch on" - I mean------ "when you close that final "switch" that provides a "continuous electrical circuit" from the positive side of the battery, through the "load" and back to its negative side.
In our vehicles "fuses" and "fusible links" protect these loads and their associated wiring from the damage that would otherwise result from short-circuits. (A "short-circuit" is where the current has found an abnormal "quick route" back to the battery. For instance via an exhaust pipe when part of the wiring has fallen onto it and the protective insulation has melted.) A fuse or fusible link protects loads and circuits by "destroying itself" (by melting as a result of EXCESSIVE current flow) and thereby provides a break in the circuit that prevents further current flow.
So one of the best ways of searching for electrical faults is to test to see where this voltage/pressure is present and where it is missing. The most common way of testing this is with a voltmeter. Here is a photo of a cheap digital meter being used to check whether the glow plugs on my BJ40 are getting voltage. (The meter shows 0 Volts now because no-one is in the cab turning the glow plugs on. If my son wasn't such a lazy sod -still asleep!!!- I'd get him to turn them on to also show you the higher reading I would get then.)
Note that there is a "buzz bar" connecting all the glow plugs together on my BJ40. This "bar" is supplied with voltage from my glow plug relay (through its "high current" open/close contacts). That current must travel back to the battery and it does so via the engine block, chassis, and the earthing lead(s) that eventually connect to the battery's negative terminal.
It can be hard to use a meter like this without assistance unless you have a "crocodile clip" attached to your earth lead that enables you to earth the voltmeter's negative probe like this:
I should explain what I mean by "earth". The battery's negative terminal is connected to the metal bodywork/frame/block etc via the "earthing" leads. So we call any of these places "an earthing point". The crocodile clip is attached to an injector pipe in the photo. That pipe is "an earth" because it is directly connected to the battery's negative terminal through flanges, bolts, and earthing leads.
t to switch (connect/disconnect) a high current. (If you use a normal switch to switch a high current, arcing/sparking will damage that switch.) You say you still hear your relay "clicking" so therefore it is still
