D
Docmallory
Guest
Vehicle - '97 LC 120K miles, fairly new to me
Preparing for the upcoming birf job, so I thought I'd assess the front brakes beforehand.
Passenger side front - both pads are evenly worn and have probably half of the original thickness left.
Driver side - inboard pad is well worn, almost down to the squealer bar. This pad is worn evenly. Outboard pad is worn unevenly, with slightly greater thickness at the front end than the back end. Overall, the outboard pad, while uneven, is not nearly as worn as the inboard pad. The outbard DS pad is almost as thick as the PS pads.
Both front rotors are moderately scored and would need to be turned or replaced for new pads.
Haven't checked the rear brakes yet. Braking is fine, with no pulls or anything. There is a very slight undulation (a la warped rotor) that is not felt in the steering wheel (so I'm thinking it's the rear brakes).
[glow=red,2,300]So, what's your diagnosis and advice? [/glow]
I have new front rotors and 100 series pads on order, and I'm guessing I'll need to order a DS caliper as well.
