I had to pull the engine, just to fix a g/box leak and replace the oil pump housing. While I was at it I thought I would lift the head for a quick peep and replace the stretch bolts which I reused the last time.
Now, mine is a late model B, with no liners and a built in vacuum pump and rotary IP.
Stay with me now:
When I first got the motor, about 10 years back she was in a sorry state and the rebuilders fitted liners. (Can’t remember why, possible because of availability of piston or max oversize exceeded, whatever).
So, I had a good look, pulled a piston and checked rings bearing etc., all good, so I fitted the new gasket and tightened down to the torque recommended on the tappet cover label.
What I did not even check, was that the gasket fitted properly!!! In this case, being a late model gasket, the piston holes are the size of the pistons and make no allowance for the fire rings of the liners. I did not see this, don’t ask me why, but I did not.
So now on tightening up, the gasket now on top of the liners (fire rings) tries to reseat the liner, and 3 liners crack, in a perfect circle about 5 mm down.
I found this out because, thankfully a piece of the squashed gasket folded into the piston bore and prevented me from turning the motor over. I cursed, checked everything else and pulled the head again to find 3 nice giant sized bangles as a present for my stupidity.
I now have a stripped down engine block, ready to go in for new liners tomorrow.
A new gasket, the correct one this time
A new set of head bolts
May as well chuck in new rings
Question:: If you are still prepared to deal with a fool.
I must fit the old model gasket (To clear the fire rings). Did these gaskets come in different thicknesses?
10 years ago, when I rebuilt her the first time, I just asked for a B gasket and fitted what I got and it worked. Not from an official Toyota dealer.
Advice appreciated, and kick my behind if you want, I am man enough to take the punishment.
George
Stay with me now:
George
