Does anyone know the thread pitch and diameter of the threaded portion of the axle spindle? Going to attempt to machine a spindle grease tool for a school project. Thanks!
This is correct.Do you mean the outboard end of the driveshaft, under the grease cap, that you use to pull the driveshaft out when installing the snap ring? It's M8 x 1.25; that's the "standard" M8 thread.
No, I mean the external thread that the lock nut threads on to. Sorry, should have clarified which threaded portion I meant.Do you mean the outboard end of the driveshaft, under the grease cap, that you use to pull the driveshaft out when installing the snap ring? It's M8 x 1.25; that's the "standard" M8 thread.
So you mean the hub flange that holds the bearings in?No, I mean the external thread that the lock nut threads on to. Sorry, should have clarified which threaded portion I meant.
That's exactly what I'm going for! Didn't want to name drop the specific tool as I know Christo frequents the forum, but if you can confirm the dimensions that @Malleus figured, then I'll be on my way.Slee makes a grease tool similar to what you're describing. I have one and can give you measurements if you want something for reference.
SLEE - Spindle Grease Tool - Slee Off Road
Screws onto 54mm spindles Allows for easy greasing of the internal spindle bushingsleeoffroad.com
LolIf you ask me what the measurement across flats is, I'm going to bill you.
M42 x 1.5 I measured a locknut, because I don't have an open axle at the moment.
