Those who installed Awning and side walls; can you report some practical experience ?
1. Would you buy it again?
2. Do you deploy it frequently
3. Is it a hassle to use
4. Did it hold under windy, rain, sand conditions?
5. Did you sleep in it as substitution to tent or RTT?
6. Did it interfere with wheeling, got caught on branches?
Thanks in advance
Sent from my iPhone using IH8MUD
Great questions. I've had awnings of two off-road vehicles with the current one being on my 60. I'll share my experiences.
A. Yes. I've found them to be useful not only in the back country, but also tailgating or car shows to get out of the weather, sun, heat and it always becomes the place for people to hangout when it starts to rain.
A. Not really. Since it mounts to my RR via small receiver hitches/pins I put it on when I think I might need it and remove it when I'm done. I hang it in my basement when not in use.
A. Not really. Once you've put it up a couple of times you'll do it with your eyes closed. But...if it's windy don't bother. No matter how many tie downs you use it only takes one updraft and it becomes a sail. Also, if you have it deployed and are going to leave the camp for any period of time make sure to put it away...otherwise the wind will kick up while your away and you'll return to it sitting on the ground.
A. See above...Nothing like seeing and hearing the sound of awning poles smack the roof of a vehicle when the awning catches air! Mine has worked great in the rain. Makes a great place to cook, sit and chat during light rains. Once the wind picks up and starts pushing the rain under the awning the fun ends and you end up inside the truck or in the tent because you never seem to park your truck down wind.... My first one had side curtains that acted like small sails, it didn't really keep the sand out, but kept some of the rain out.
A. No. Since I've had RRT's I've napped, sat and cooked under the awnings but never slept all night under one. I'm sure it would be comfy as long as the wind didn't kick up at night and then your rushing to put it away.
A. Yes. When running some trails in Moab it snagged on some trees on some tight trails. The cover got cut a little. Also, if you lean your truck up against a tree/rocks it'll defiantly snag on something...
Hope my limited experience helps.
Good luck
