I'd think you could just disconnect the sender lead to the wiring harness and wire an aftermarket gauge. But then your ECU won't have a proper temp reading? Your factory gauge in the dash also wouldn't work.
Can two gauges work off the same sensor? I don't know, but that way everything above is OK and you have an additional backup in the aftermarket gauge.
SNIP
i have the raventai mod and i can see my gauge move up and down, in the heat with a/c and aux fan its 3/4 way on the factory gauge. i wish i knew what temp reading that was. when the engine is under load going up a hill it can go right under the red mark on the gauge.
No!)))) 244Thanks for the insight on the ECU. I figured it required a temp reading, just wasn't sure.
For temp readings based on your dash gauge, these are the ones I have pulled from the Raventai thread, IIRC, in F degrees.
Pegged Cold 150
Cold Line 160
Centered 189
Bottom of Red 217
Top of Red 227
Pegged HOT ((((OhNo!)))) 244
Ouch, sorry to be the bearer of bad news
If it was me, I'd go for a new radiator at this point. Rodding out helps, but I doubt you're getting factory spec flow if it was plugged that badly to start with.
If worse comes to worst and the HG goes, I'm sure there will be plenty of folks interested in a locked 80 with that few miles. But let's hope not!![]()
ok now those numbers are really scarring me. i modified the fan clutch and put 10K toyota silicone, new toyota thermostat, toyota red coolant (70/30 mix more water then coolant) i rodded out the OEM radiator, it was about 35-40% blocked. my temps still rise up when im going on a steep uphill on the freeway. i should do something about reading actual temps. mine is still the original headgasket and i dont plan on changing it.
noo i will never get rid of my landcruiser. rodding the radiator did help, but for the sake of keeping my headgasket from going out, i should opt for a OEM radiator or the Koyo. not sure yet. Mine has gotten to 218 where the AC cut off and the needle is still in the center with no movement
Ok. Embarrassing noob question, be kind....but why is the radiator cap so important? When people talk about the cap do they literally just mean the cap at the top of the radiator? Why does it play such a big role in the cooling process?
Thanks.
