Average operating temp
bajaphile
Boojum Hugger
Solana Beach, CA
What is your average operating temps? What range does Toyota give?
My Ultragage has been reading temps in the 200f range in stop and go driving. Seems a little high but not sure.
Radiator replaced a few years ago with OEM Toyota. Thermostat new. Coolant flush within last month.
Might look into doing a new fan clutch.. Or maybe a small aux fan in the front of the condenser. Looks like there plenty of room
I'm running 180-195 stop and go 90 degree heat with the a/c on
192 w/ AC on, 186 AC off @ 90-95 Ambient...this after full dealer flush and new hoses...:cheers:
200 seems high, I was asking the same questions in my build thread. I went through everything (thermostat, system flushes, fan clutch, water pump, and finally new rad) they all helped a little so I can't point my finger at any one thing, but since most of your components are new I would do the fan clutch it is simple and easy.
Hmm.. Yeah sounds a bit high then..
So I need to buy a new fan clutch "blue hub"... And add 15k weight silicone oil..?
I think that's the next step. I dont hear any fan roar when I start up the truck.
You can buy them from Aisin cheaper. Same clutch, just not branded as Toyota. FCT-004 is the number. I'd buy that and replace with 15k or 20k cst oil.
Hey Greeenbomber,
I am 179 to 192 deg. F with AC in your same neck of the woods. In the last year: new OEM rad/stat, blue fan clutch, flush, 25% Toy red, and distilled water. I have not modded the blue fan clutch with new cst oil. I do not think I have seen more than 200 deg. F on the scan gauge for more than a 30 sec in the last 12 months, even pulling a trailer. I do hear the fan roar for several seconds upon start up.
I am using redline water wetter; some folks have opined that this does not work well with Toy red. I have no idea if it helps or hurts.
Just got through doing this with a new Aisin (15K) and it's a vast improvement. Definitely moving more air, highly recommend it. $79 shipped (ebay), less than $10 for the CST.
Before I worried about OBDII reporting 195F on one 80 and 200F on another 80, I would WANT TO KNOW THE ACTUAL ACCURACY of the temperature sensor...
cheers,
george.
My AC turned off for the first time the other day (just installed all the armor and I hope is just the extra weight). So I ended up getting the scangaugeII and in fact it was running up to 218 briefly on the highway but cooler on the street. This weekend I installed a new toyota oem fan clutch and temperatures are cooler but still got up to 202. It still seems high compared to some of you guys. I haven't heard the fan really "kick-on" and I wonder at what temperature is it supposed to.
104deg in the valley today. Hottest the LX got up to was 196deg. And that's with a 303 and a 404.
Out of interest, how are you measuring the temp?
I have a 1HZ and the needle on the dash never moves. Recently invested in an IR thermometer so i can check individual components.
Sorry for the dumb question!
womble,
There's something called the Raventai mod for the temp gauge to permit it to act more usefully, but it was developed for the 4.5 gassers we drive here because Toyota doesn't give us a diesel option. The temp gauge is deadened to disguise temporary peaks temps from freaking the driver out, then point out the fact you'll be buying a new head gasket seconds before the steam erupts under the hood.
OK, I'm exaggerating a little on that, but not much.
I believe there was some discussion in that lengthy thread on diesel apps, but you'll have to scan it to confirm. The result is a working gauge that is useful in monitoring what's going on.
It's a long way across the Australia if you've got to be popping the bonnet every few miles to point that IR thingy at something. But you're right, gotta love that IR thing, as I keep one, too, in my console in case it's needed.:)
It does sound a little high. I had a similar issue last year. I ended up installing a foam seal that had been removed by a PO between the radiator and upper support bracket. this helped some. I then drained my existing fan clutch (OEM Aisin) and replaced the fluid with 10k silicone fluid. This mad the biggest difference, but both improved operating temperatures. Total cost of these two repairs was about $15. If you or a PO replaced the OEM fan clutch with a cheap knock off, then a new one would be in order.
Mine was running 214 in Phoenix, summer temperatures 108, a/c on max and stop and go driving. Now I stay around 194.
^^^This.
All of the factory types can be refilled, aftermarket ones are not worth messing with. Best fluid viscosity depends on clutch type. If it's an Eaton, will almost never hear the fan and they can be very effective.
cheers,
george.
In my case, I rely on an aftermarket temp gauge. It's always within 1~3º of the ECU's reading.
Yeah I'm not sure how accurate the scan gage or Ultragage is really. I'd like to install an aftermarket gage. To thr previous poster, can you give a link to the pod setup as well as where you tapped into the engine for a sending unit?
