I have a 2014 GX460 premium
I want to put an auxiliary LiFePO4 battery in the rear cargo area. I’ve read a few posts and watched some 4Runner vids on running wire to the rear cargo area from starter battery <-> inline fuse <-> BCDC <-> aux batt.
I’ve also read a few posts about the 120V (100w) inverter and it’s utility, or lack thereof.
Questions:
I was wondering if I can cut the 12v wiring to the rear inverter and connect to a BCDC <-> aux batt <-> fuse block -> new inverter.
Additionally, I have the premium model. The luxury model has the power 3rd row seats. Is the wiring harness the same between luxury and premium and does that mean I can use those unconnected lines for an aux power solution?
Goal:
1) less wiring, 6awg or 8awg
2) I can replace the limited utility inverter with one of my choice running from an aux battery
3) Add more 12v receptacles
Drawbacks and concerns:
- Is the current cable feeding the inverter capable enough to feed the a 1225D BCDC? If I read the fuse block diagram correctly, it is fused at 15A, which is cutting it really close.
- I would have to full time carry an aux battery for those AC and DC ports to be live. But if I can fit a battery under the wing of a drawer system, I would do this anyway.
Edit: corrected info on fuse for inverter, added question about power seats for luxury model.
Questions:
Goal:
