What is the capacity of an OEM diesel 60's fuel tank? Thanks.
Diesel or gas '60's use the same tank. Only the suction fitting changes as some have a return and some don't. 90 liters is the specified capacity.
Not to shabby. In terms of load balancing between the tanks if you could find room opposite the OEM tank on the driver's sides it would seem that you'd be ok. If it could be done then I'd plumb the aux tank to a 80 series Y filler neck at the OEM spot and use a fuel solenoid to control both tanks. Use the stock fuel pump and gauge. I think that the same solenoid setup allows you to wire the senders from the both tanks to it and then to the fuel gauge, so when you flip the switch the gauge on your cluster goes from taking its reading from the main tank sender to reading the aux tank sender.
cruiserguy thanks, good to hear from you are you back in Canada or still down this way in Guat?
Sounds great. I'd love to have you come on by, grab some hot pizza and cold beer and take a look at my rig. Progress is going slow but going. Things ought to be farther along in September. Just let me know when you plan to make your run.We're back down in Guatemala after 25,000kms over 2 months on the trip up to Canada and back down again. Hoping to head off to my buddy in Honduras in the next month or two and maybe we can meet up since it didn't work last time.
Josh,
Hey, how are you and where are you these days? I haven't stopped thinking about this topic and in looking at the options I totally forgot about 60 tanks as aux tanks. What is the capacity of an OEM diesel 60's fuel tank? Thanks.
Also, I should be back up in central america around october, if anyone's around...
Is everyone using a separate filler neck from the main tank? Does anyone have an idea where to find a stand alone dual filler neck?
. More importent is to have sufficient breathers, at least 10mm !!My mate has one on his HJ61 mounted there and he has another mounted next to the tailshaft for a total of about 250L. Both made from steel. Sorry don't have any more details on it.
We make boats at work and we build our own fuel tanks. If making it from alloy make sure you get the correct grade alloy. A lot of alloys will get micro cracks in it when folded. I can't remember off the top of my head what grade the boys use ( I don't actually make the tanks). Make sure you leave an expansion void in the top of the tank above the maximum fill capacity to allow for hot days. The breathers need to be located properly too so it won't be a bitch to fill. Try to keep the filler and breather tubes from having low points in it too for ease of filling. Don't forget a drain bung in the bottom too.
5052 is the common aluminum alloy used in the States for fuel tanks. The key is to not use one of the Heat Treatable alloys like the ubiquitous 6061 as those will crack when you try to bend it.
In the U.S. it comes down to the two common choices, 3003 or 5052, and 5052 is the stronger of those two alloys.
