aux fuse block / terminal strip
morristown nj
with all the goodies...ie fog lamps, cb, scanner, I'm trying to figure out how and WHERE to mount an extra fuse block / terminal strip to hold all the wires.
I got a ground bar from an electrical supply, and bolted it to the firewall area behind the radio, so the grounds are not the problem. it does not need to be super-accessable like the original fuse box, but somewhere i can add stuff to when i need to.
any sugestions?
ps no one want my seat covers in the for sale section? good shape, just pay for frt. 10 bucks!
after sunday, in the trash they go. and i swear...there are in good shape, I'll even wash them first!
hammer
there's a good flat spot on the firewall with easy access just to the right of the wire harness pass through grommet on the passenger side -- you'll see it but you will have to unbolt and set aside the washer fluid tank first.
makes for easy routing of additional wires through the firewall and if you use the Painless Circuit Boss kit, the new fuse box is serviceable without having to remove anything once installed.
hth,
-dogboy- '87 FJ60
I mounted mine right in back of the battery on the inside engine compartment. Basically there is a spot right behind it on the inside right. Works well and you dont have to run a power wire all over the engine compartment.
