- Thread starter
- #21
I took the seats over to an upholstery shop today. I decided to go with a light grey cloth interior on the seat faces and color matched marine vinyl on the bolsters. They should be done next week.
Shout out to @Living in the Past or anyone else that may know.
My fj45 has no heater at this time. There appears to have been one at one time, maybe aftermarket? I say aftermarket because there are no provisions for a blower motor in the engine bay on the firewall like all the other fj4x I have seen nor is there any sort of block off plate for the air to have passed through. The picture below is in the cab where I traditionally see the factory heater. There is a block off plate there but no way for any kind of elbow to be installed in the engine bay to feed air through that hole. Could this block off plate been the original source of air for a self contained heater fan in the cab?
Your biggest issue is that is a RHD. Pretty easy to install a factory heater if you have all the parts. That 84 HJ47RV had a RHD heater. The duct between the blower motor and heater coil had a A/C evaporator. Didn't pick it up since I didn't have anything RHD. I have all three version of the LHD heaters.Shout out to @Living in the Past or anyone else that may know.
Not sure your direction but I just removed the rear heater out of my 80 you are welcome to.
I don't see how I could install a blower without cutting a big hole in the firewall. Do you know if any of these were built with no heater fan? I.e. Like just a radiant heater?
Thank you, Phil. I will take you up on that. I am not sure there is an OEM solution for what I am looking at.
Cool truck. If your interested in adding a lift, I have some 3 inch lift Alcans springs I plan to sell. I will make you a hell of a deal.
Not the best look, but not terrible with the Tacoma steelies. I needed something cheap and safe to drive on. The OEM 16" split steel wheels had pretty old 7.5 16 tires that I couldn't trust on the road.
That bed would make a nice platform for a roof top tent(?)
I posted pictures of a couple different Toyota Aluminum rims on my 45 in the what did you do to Land Cruiser etc etc thread. For the direction I thinking of going with my 45 the factory split 16" rims would probably fit best. Not sure I can do it. Like the 91/92 80 series wheels. Posted pictures of them October last year I think. Remember still had a cast on wrist and doing one hand tire changes.
Has the newness of the truck worn off and moved from the garage to the backyard and a tarp?
