- Vehicle Model
- 80 Series
Also listed on Facebook: Log into Facebook - https://www.facebook.com/marketplace/item/1091974929685325
Fully rebuilt 1FZFE long block for sale.This came out of my 1997 triple locked Land Cruiser originally. Sold the truck and no longer need this rebuilt motor. Located in Round Rock, TX (near Austin)$4500No i will not ship it, if you want it you need to find a way to pick it up or arrange shipping.
New OEM Toyota parts:
- new head gasket
- new intake and exhaust valves
- new valve springs
- new valve retainers
- new valve seals
- new piston rings
- cleaned pistons and carbon removal
- stock bore size, inspected and in good condition
- ball honed gently for fresh crosshatch
- cleaned oil squirters
- cleaned all coolant and oil passages
- new ARP head studs
- cleaned cam shafts and oil passages
- new rod bearings
- new water pump
- new front man seal
- new rear main seal
- new oil pump gasket
- new valve cover gasket
- new valve cover donut seals
- new cylinder head “half moon” seals
- new water neck gaskets and o-rings
- new exhaust manifolds
- new exhaust manifold gaskets
- stripped, primed, and painted valve cover
- new oil cap
- new crank pulley (harmonic balancer)
- new timing cover o-ring seals
- new oil pressure sensor
- new timing chain guides
- new timing chain
- new hydraulic timing chain tensioner
- new exhaust manifold studs
- new exhaust manifold split top locking nuts
- new oil cooler gaskets
- stripped and resealed upper oil pan
- stripped and resealed lower oil pan
- new oil pump cover bolts
- machined cylinder head
- cleaned, stripped, primed, and painted engine block
- new EGR block off plate
- new exhaust manifold to exhaust studs
- new exhaust manifolds to exhaust locking split top nuts
- new manifold to exhaust gaskets
- new intake manifold gaskets
- new upper to lower intake manifold gasket
- new throttle body gaskets
Includes following, but not installed.
- throttle body
- upper intake manifold
- lower intake manifold
- fuel rail and stuff attached to it
- fuel injectors
- all gaskets for these parts
- etc…
I’m sure there are other things I’m forgetting. Message me with any questions.
- new head gasket
- new valve springs
- new valve seals
- new piston rings
- new rod bearings
- new water pump
- new oil cap
- new timing chain
- throttle body
- fuel injectors
- etc…
