Audio for a 24v diesel (1 Viewer)
Japan
I have a 24v 1pz and I want to upgrade the head unit but not instal an amplifier or extra speakers. I was under the impression I needed a 24-12 DC-DC converter. I pulled my OEM headunit out and it had a 12v sticker on it and I read out the connector and had two pins read ~14v.
So, am I misunderstanding this and the rig will accept a 12v headunit just fine or should I find a 24v marine unit to be safe? I do not have the FSM and I am having no luck finding wire diagrams for the rig. Any input you guys have is appreciated.
All the newer stereos I have installed for myself and family get their main power through an unswitched, always-on "memory" wire. The red power wire merely provides power to the on-off switch of the unit. If that 12V wire you located does not depend on ignition switch it will be easier.
I want to know this too. Thanks for posting.
Hi Tcash
If that is the original radio that was installed in your 1PZ , it means that you also have an 24-12 converter installed , perhaps an original one . Modern radios , don't work very well with these converters . I strongly advise you to choose a 24 volt radio . I did that and it works perfectly , connected only to the ACC fuse on the fusebox . The best ones I know are from Kienzle , VDO and Continental . Made in Germany , and build for use in trucks . Bluetooth , handsfree telephone , etc. ! Kienzle models have very classy looks and all of them are very user friendly to operate . And they are not too expensive . I have this one in my HJ61
https://www.kienzle.de/uploads/media/MCR2416BTK.pdf .
Visit this page ( Germany ) and you will see various models from Kienzle , Continental & VDO
Cheers from Portugal !
And this one is , perhaps , the best shop in Europe to buy these and lots of other 24 volt radios
They sell on eBay.de , too
Very efficient and professional seller .
I have an aftermarket cheapo Dual brand head unit in my 24V rig, wired to the factory plug and what ever factory 24v-12v converter is there. works just fine. :meh:
Why go thru the extra hassle to wire a separate 24V feed to the new stereo? if a 12V head unit was already there just plug a new one in and go.
CAT makes a really good converter that offers both constant 12V and intermittent 12V from the same device. Been using them for several years now without issue.
How do you wire it and what type of plugs do you use?
My local CAT shop would make me a pigtail with the correct plug for the converter and foot long leads coming from it. That way I could wire up any accessories I wanted and how I wanted.
Was trying to see if anyone else had success by using a regular 12v unit... I am trying not to modify or add to something that doesn't need it.
Hi Tcash
Thank you! I was figuring going with a 24v radio would eliminate concerns. Just seeing what others have done. Thanks for your response! How are the rigs in Portugal? Are they set up for more desert/dryland conditions?
Hi Tcash
These 24volts radios are very practical , very simple to install , very sturdy and user friendly on daily use . I have one of them installed in my HJ61 wich is 24 volts , and soon will install another on the 1999 HZJ75 I recently acquired . Rigs in Portugal usually have a very simple setup due to very rigid ( read stupid ) traffic regulations . Every minor alteration must be homologated by the traffic authority , by a lengthy and expensive proceeding . Even so , there is a good number of rigs setup for desert travel . When we can , we go to Morocco , Mauritania , Senegal , Guinea Bissau to have fun ! Nowadays , it is too dangerous to go to Mali , Niger or Libya , like we used to . It seems that Algeria is slowly getting more safe and we are receiving good feedback from some local friends there . Offroad in Portugal is still allowed in most parts of Portugal but it does not requires important modification on our rigs . They are already very capable as they come from the factory . Good luck with your PZ7# !
You have a factory converter for your stereo located behind the glove box. I removed the stock unit and replaced it with something more modern with Bluetooth and USB hook ups. Been running it for years and never skips a beat.
What, exactly, is this vehicle? All we have to work with is an engine and 24 volts. It is difficult to provide definitive recommendations without the whole story.
