Atlas vs Orion
With all the other gearing options, I cannot see any reason why you would want to increase the overall length of the drivetrain by another 8" to add one of those....especially when you can get a Stak.
:beer:
4 speed atlas basically has a klune on it already...
Klune/Atlas = $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Stak is a lot cheaper.
wngrog said:
Get the Stak 3 speed case and go as high as you can in the diffs. This will be an issue with the portals.
Not really, the Portal-Tek's can be specified with a gear ratio from 3 :1 to 7.33:1
wngrog said:
Man, I LOVE the 4 speed Cruiser case.
mine came with a 3 speed ... I think ... it's been a while since it was replaced :flipoff2:
Now where is that paperwork ... it's a 73 .... I think ... hmmm .... It does not matter I dont have the box anymore!!
I meant 4 speed tranny.
Anyway, I have not been following the Portal Tech stuff, but 3:1 final or is that the diffs plus reduction? There has to be some reduction in the portals IF they are really portals and not just high-center axles.
Anyway, 3:1 to 7:1 sounds to me like your choices in the 3rd member befor a 2:1 portal reduction. Clarify that then decide what you want for a final drive ratio. Then lets come up with a plan :)
That's the nice thing :D, it's the final ratio! :bounce:
I have a quote with a 2.47 Ring and pinion and a 4.94 final :bounce2:
I know of no 1.5 ish ring gear ratios so I just don't know how they can do a 3:1 final.
Anyway, back to the original question: Which case.
Lets say you stick with the SM420. I know Medusa will hate this, but to keep it simple, lets round down/up to the closest number here for ratios.
SM420-7:1 x Portal Tech-5:1 x STAK 3:1/5.5:1
That gives you 105:1 and 192:1 for your crawl ratios.
Toyota 4 speed-4:1 x Portal Tech-5:1 x STAK
60:1 and 110:1
I like the SM420 options there the best. 105:1 is a great final drive for crawling and use of 2nd gear to get the wheels spinning.
192:1 is sick, sick, sick and will be a fun ratio to have when you want to play with it.
I vote to keep the SM420 and get the STAK in the current ratio they are offering.
Yes, yes it is.
Those are basically my gear ratios right there. I am VERY happy that I have the ability to lose that 200:1 ratio tho..
And if I keep the Ranger OD (83:1 & 152:1) I also could cruise HW at a decent clip without over-reving the v8 ... road trip! :rolleyes:
Anyway, if 192:1 is so sick ;) and loosing it is good
then why not go to a 4.5:1 (75:1, 95:1, 135:1 & 172:1) or 4:1 (66:1, 84:1, 120:1 & 153:1) final ratio?
:censor: I'll need ear plugs for all the gear noise and a map and guide to all those levers :flipoff2:
200:1 is entertaining, don't get me wrong.
But I would hate to have that be my low range ratio...
What revs are you looking for on the highway?
ah, I understand.
Well working it backwards, 55 and 70, with 35'' rubber, OD and 4.88:1 final would be between 2 and 2.5 K rpm, with 4.5:1 it would be 1.8 to 2.3k, hmmm :confused:
I've never driven an FJ with a big V8, so is that high? :o
No, 4.88 should be perfect...
Just out of curiousity how many of you guys talking about the stak box have actually installed one? They are freakin huge compared to a Atlas or an Orion. HAs anyone dealt with tranny tunnel issues or are we just settling for a bunch of crap hanging below the frame rails.?
Well aware that the STAK box is larger than an Atlas or an Orion....buddy is installing one in his buggy...
I had to modify the floor/tunnel of my Red truck when I installed my Atlas, so that I had flat bottom, because I was sick of the stock Land Cruiser case hanging low...and I am running a three inch body lift.....
Other than an Orion, there is no getting around this bud....no matter Atlas or STAK....
Good luck!
-Steve
