Atf leak (1 Viewer)
Orange County, California
Installed new radiator and lost some tranny fluid in process - refilled - all good on atf fluid level but now appear to have a pretty significant leak....any thought on where this is coming from?
Higher up
Higher again.....
Uh oh.....is my head gasket gone....
Is it coolant I'm seeing and not tranny fluid...?
Unfortunately...Yep
For kicks, you ought try a bottle of Blue Devil Head gasket sealer and report back. I poured a bottle in Ford work truck that was burning about 2 gallons/week and all has been good since last summer. Your's isn't burning it so I'm not sure the results. We all know the right/long term way is to change it. Just thought I would buy you some time...
Dang it - not seeing anything in the radiator - no drop in engine performance as far as I can tell....$@&&$?
Just installed a sweet gamviti rack as well for an awesome road trip I had planed this a coming Friday.....
Oh - and thanks - hoping I could have pushed this known monster of PM until next year but.....
read through this
https://forum.ih8mud.com/threads/head-gasket-questions.815477/
some pretty good info there - think I'm leaving work early to clean up exisiting leak mess and see if i can locate if the leak is actually coming from the head gasket - or somewhere above maybe- have dashcommand so will keep an eye on engine temp.
Was supposed to be heading out on a 700 mile round trip this coming friday.....yes....I'm clutching at straws....
Yeah, radiators and HGs seems to come together in these rigs as they get older. That's why I'm suspect if an 80 Series for sale has a new radiator.
cleaned things up and dried off underneath to see if i could track down leak some more.....
appears to be coming from the seam
but then a little bit later - leak seems to have migrated to rear of block - could have been just down to me driving around.
With regards to the cooling system - everything is new - all hoses etc - except this mystery hose which apparently runs under the throttle body - couldnt get to it....
local garage says a hydrocarbon test will be definitive proof..doing that tomorrow morning - under 100 bucks.
Blackstone is $25. Just saying...
