AT coolant line Inlet at radiator broken (1 Viewer)
Massachusetts
Hey There.
I have a leak at the bottom of the radiator on the drivers side. Its the inlet for the AT cooler hose. Basically looks like its corroded apart.
Does anyone know if the inlet is replaceable? Am I going to need a whole new radiator?
Thanks for your help!
Odessa/Midland TX
Do you know the history of the radiator? If it hasn't been replaced for past 5 years, get a new radiator before you experience the pink-milkshake.
JunkCrzr89
Competent Ignoramoose
Colorado
Hey There.
Thanks for your help!View attachment 2560277
Based on your photo, I don’t think the leak is coming from the hose connection at the A/T cooler.
Massachusetts
Answered mu own question, part is not sold separately so im in for a radiator swap this weekend
JunkCrzr89
Colorado
What part? If you’re talking about the fitting for the A/T cooler line, that’s not where your leak is.
Massachusetts
For all I know its the factory radiator.....
The fitting for the AT hose actually broke completely once I touched it. It looks dry in the picture cause I wiped everything off......
The fitting is definitely leaking, as far as I can see there isn't a leak anywhere else.
Is the pink milkshake made of AT fluid and AntiFreeze? Sounds yummy
