- Thread starter
- #21
I'll touch on my tire movement concerns in the next post, but for now, here's the results of my getting impatient and just finishing things up over the weekend.
It meant I also finally got a full night's sleep, which was freaking fantastic.
I think it looks pretty badass. The lights aren't wired up yet, neither is the trailer plug, and I have a set of LED license plate bolts that are coming in the mail sometime this week, but it's basically done for all intents and purposes.
The bracket at the top of the ladder is in place so I can bolt on a vertical hang bike carrier that I'm planning on building later, but it still living only in my head right now. It could also serve as a mounting point for other goodies in the future.
The 10-32 studs on the ladder arm are welded on and kept clear for wire routing. The intention is to use a small nut to hold on some straps for the cabling, and then cut the remaining off.
The Synergy Mfg. spring pull pin to hold it open glides up on that piece of 1/2" plastic bolted to the top, that way the pin isn't riding on the metal surface, which would eventually wear through and cause a rusting issue. I really like how these look and work so far. I got the plastic as some scrap leftovers from an extruding shop at work, countersunk a hole in it, and then bolted them down with 1/4" stainless hardware.
The backup lights are just $18 ebay LEDs, but they will be fine for my needs. They look EXACTLY like Rigids, but without the extra $130. Good enough for me.
I wire wheeled the crap out of everything, degreased it, sprayed with a self-etching primer, then a light scuffing with the 80 grit, then finally a few coats of Raptor Liner at about 50PSI.
With the weight of the bumper and tire back there, it caused the rear of the truck to drop by about 3/4", but that still leaves me with around 25 1/2" from hub center to fender flare. I have no idea what type of springs are on the truck, but I'm perfectly happy with how it's sitting right now.
And yeah, re-doing the exhaust has been a plan for a while now. At the moment, it still moves combustion gasses to the rear of the vehicle, so no rush.
