I'm in the middle of trying to fix an ongoing P0401 on my 1996 LX450.
before I go on, I would like to humbly request that if anyone knows someone who work at Toyota who helped design and locate the EGR pieces on the LX450, please, hit them in the face with a shovel for me.
I've only seen this stupid of engineering once before in my life, on an Oldsmobile, and that's debatable.
I am following the outstanding thread posted by cahill found here : PO401 and EGR/air intake manifold with pictures
I am looking at the bottom of the manifold which looks like this:
I have replace a vacuum switching valve which is labeled #1 in this picture, that's replaced.
I also found a completely blocked vacuum hose connection into the manifold which I cleared
but notice in this picture, towards the bottom just south of the number 3, and behind the black hose that has the text "HOSE#" on it, there is a little brown thing showing.
It looks EXACTLY like the vacuum switching valve that threw a P0401 on my 2001 Toyota Camry. I looked at the part number on the part an it's this thing:
a Toyota Vacuum Switching valve. Part number
Toyota 90910-12043
https://www.amazon.com/Genuine-Toyota-90910-12043-Vacuum-Switch/dp/B00GJJKS9E
So my question is: do I need to replace this one too? I am going to be pissed if I put this thing back together and then have to take it apart again.
the part is 95 bucks so preemptively replacing it will sorta hurt, but it would be better than having to tear the manifold off again.
none of the threads I've read have mentioned this part, so I am not sure if I should replace it or not.
Any thoughts? I wonder if I could test this easily by jumping 12 volts to one of the pins and seeing if anything happens.
Toyota 90910-12043
