Are 22r and 22re parts compatiable????
I need a throttle position sensor and the only one i can get is off a 22r motor and i have a 22re? Will it work?? If you know please let me know
thank you
22R Does not have a TPS.... So you have some misinformation somewhere... I'm not sure on year TPS compatability, but my thought is if anything is different, it's the early (85-86) TPS vs. the later (87-95) Can you check the part numbers on them?
Are you sure yours is bad? Have you tried adjusting it?
22r is a carburated motor, and 22re is fuel injected. A 22r wouldn't have a TPS.
how do i adjust it?
Dude, 1st off welcome. And second, there is a WEALTH of info in the FAQ. Look at the sticky's to find it. Click on it, and have a ball. :flipoff2: < newb welcome :cheers:
If you read the FAQ, and PM (Preventative Maintenance) the heck out of your truck, it'll be the last one you'll ever need.
........unless it's a 2wd....then you'll need to get a 4wd :D
EDIT: And also, this is a MUST!! DL a FSM (Factory Service Manual) provided to you for free in the FAQ
