I was dumping some pics of my camera today and came across a couple I hadn't posted when I did my install of the ARB bar. There was a couple of things that made it easier on the install.
One, don't mount the black bumperettes until the very end because you have to tighten the bolts that hold the bumper to the mounting frame through an opening that is eventually covered by the bumperettes.
Two, I was able to use a 3/8 slim-head socket wrench with a short socket to tighten the bolts that hold the bumper to the mounting frame. This was a lot faster to get the bolts snugged up to adjust the bumper spacing to the fenders than using a regular wrench. The bumper wall is at a funky angle and a regular socket wrench won't fit. You'll see what I mean while you're in there.
Overall, it was a pretty easy install. I was surprised to see that there was a separate mounting frame that holds the bumper to the frame of the 100. A winch mounts directly to the mounting frame and not to the bumper. I've had 2 other ARB bumpers and the winch mounted directly to the bumper on them.
The Air bag crush cans (the accordian looking section in pic 3) are in front of where the winch mounts, so you don't have to worry about the bumper shifting while pulling with the winch. This happened easily on the ARB on my LR Disco 2.
I've wheeled with it once now, and so far I like it a lot. I'll be adding a winch after Christmas, so I'll have to take the bumper back off then to mount the winch.
The first pic is with the factory bumper and grill removed. Now that's some crazy approach angle! The second pic is with the grill back on and the mounting frame installed. And the last pic is a close up of the mounting plate. The square plate in the middle is where the winch mounts.
