Anyone use Eimkeith RAMs AND Delta VS Arms? (1 Viewer)
Chandler, AZ/CFalls, MT
Currently running 37's on an unknown lift with some kind of unknown caster correction plate (PO installed).
I want to run 40's, but would like to push the front axle forward 2". My thought is using the Eimkeith Radius Arm Mounts PLUS the 3" Delta arms with the extra 1" of length built in.
Anyone running this setup successfully? With what I expect to be a 4" lift, it will have over corrected caster a little, but I'm thinking it shouldn't be too much.
So you want to increase your ground clearance with 40s then negate all the gains by lowering your radius mounts?
Why not just 3-link or get the 5L arms.
A 3-link is cost prohibitive. If the 5L arms kick the tire forward 2", then I'd go that route. But again, looking to push forward 2". Do you know if this is the case?
And negate all gains? Hardly. Two little spots for the radius arm brackets isn't going to "negate all gains".
Ya ok, you’re opening a lot of negatives but if you want to half ass it go ahead.
The 5L only moves the axle forward an inch. I would do a search on what others have done to get 40s underneath.
Good luck.
Why do you want to push the axle forward 2"
It will just create other issues.
Anything that you do or want to do on you 80 has already been tried.
1" is the magic number to move your axle forward and still run control arms :cool:
i think your steering will hit your diff at 2" forward. it gets pretty close at 1"
Delta 5L and lots of trimming. And I would get a DC shaft if not already
It’s not the steering it’s the panhard that gets close.
And 2” it will most likely be binding.
It will also push the tires into the radiator support.
