i use gear oil with high pressure with a spray gun with the gun on full spray.looks like s*** but where i come they use alot of salt![]()
dad always done this.but he done it differently.Best solution, period. Drips for a day or so, but it works. Straight 90W (buy the cheap stuff at WalMart or Pep Boys), heat it up on the camping stove, then spray it with a metal bug sprayer jug. I do this at least once a year, and there are sections of the frame on my '87 that I can scrape the goop off and I could actually wax the original factory paint job if I wanted to. I live in the hard-core rust belt, we use too much of that salt around here, it sucks.
Between treatments I use Amsoil MP Heavy Duty Metal Protector, very convenient in 16 oz spray cans. I go thru probably 4-5 cans a year, usually a can every time I change the oil, spraying hear and there as a touch-up where it needs it. It dries to a waxy-like coating, good stuff.
POR15 sucks, I hate that crap. I'll NEVER EVER use it again. Did all the prep work, followed the instructions to the letter, it flaked off a year later. Then the stuff got hard in the can, I've had to throw away more than I've used. Now when I install new parts or do welding on the frame, I give it a good coat of Rustoleum primer, then 2 coats of satin black. Then the oil treatment.
Hey macneill- Could you elaborate an the 3M product you put on the 60? Is it a preventative measure or can it treat already infected areas? I live in the Metro NY area. Curious to know if you had it done locally. Thanks.
yep straight 90Multi-weight oils like 75W-90 and used engine oil will attack the rubber and plastics, single weights don't. I've always used straight 90W, no problems at all.
I think my biggest problem with POR15 is that it's just not worth the aggravation and expense. IMO Rustoleum works just as well, it's a LOT cheaper, lasts almost forever in a sealed can, and you can buy it everywhere.
it still stinks but after a coupls of days it goes awayThats good to know. I guess I'll go with the 90W then cuz it definetly sounds better. Does it smell as bad as when it comes out of a diff? God I hope not! What's the science behind why multi wieght oils rot rubber but singles do not? Just curious.
The gentleman who owns the Krown franchise that does my annual spray tells me to avoid washing the vehicle in winter with a high pressure to avoid stripping the coating ALSO gave me a lengthy lecture on "why things rust" ... pointing out that dampness causes it and salt just attracts moisture...dry is good he emphasizes!
.. well that is what I responded with as well .... and he said "depends" .. if after washing the vehicle it doesn't dry thoroughly (which it typically won't where I live - southern Ontario - damp cold and hovering +/- freezing regularly) then it is best to leave it... if you are in Utah where I imagine your relative humidity is low...washing would be ok...just dependsSo the smart thing is to wash the salt off as often as you can and keep your truck clean as much as possible
