Anyone running Baofeng UV-5R for mobile
Kansas
Just passed my technician test yesterday and have been looking around at a first setup. I don't want to spend a bunch of money on something i'm just getting into, since I don't know what I like / dislike yet. The guys from the local HAM club recommended getting a Baofeng uv-5r with an upgraded antenna and the USB cable for programming. I have also seen a lot of the guys on here recommending this radio. I think this is the route I am going to go.
However, I have really wanted a mobile setup and I would like to be able to take this portable and plug it into my 97 FZJ. I was thinking about mounting an antenna on my rig that I could plug the Baofeng into while I was driving and hopefully boost my range. What would you guys recommend as far as antennas / setups in order to use this little radio for my first mobile setup ?
Hi all,
You can buy from Ham Radio Outlet a 5/8ths wave Hustler brand mag-mount antenna that includes the coax cable. Mounted on the roof of your FZJ80 it will definitely help that little 5 watt radio transmit farther. Also, look into repeaters in your area; this is the real way to extend the range of a 2M radio.
Regards,
Alan
One of the down sides of a 5r, I've read, is from high gain antennas. Not even the roof top type. You can google about upgraded rubber duckies for that radio. I think an icom or Yaseu model is better made and from my experience you won't run into the overloading problem.
There is a new radio, the GT-3, that is supposed to be a better version of the 5r.
For a beginner I'd get an HT and have some fun. After using it you will gain experience and have a better understanding of what you want and need from a radio. In the long run you might end up with a dual band mobile which in the scheme of things is the most expensive, more so than a mono band as well as a dual band HT. Starting with a dual band HT will give you both commonly used bands and your only low side will low power and battery life. Keep in mind this is an HT thing even if you buy a $300 HT.
I always hit the trail with my 8800-R mobile in the 4Runner as well as an FT-60 and sometime by Boafeng 3r. The HT's can get that extra bump using crossband repeat on the 8800. Plus if I need to leave the vehicle I have a choice of what I need to take with me (big or small).
Some commercial radios can be had for cheap, HT and Mobile. If you have access to one and someone that can program one for you can get have quality equipment for cheap. I've got a commercial Motorola hand held with monster battery and clip mic for some work I do. I had it programmed to VHF band and the same frequencies I have in my other radios. Only down side is in-field programming, power level and squelch but I kind of know where those should be so had it programmed as such.
I use the Diamond SRJ77CA antenna on my Baofengs - has the female SMA connector that matches the radio. I really don't like using it in the vehicle, though. I got a dedicated mobile radio for that. I do like to use crossband repeat to hit distant repeaters from the handheld at hunting camp. The truck radio has 50W and really gets out there.
But a Baofeng is a good starting HT for cheap so get one. I have 2, as well as a Yausu FT-60. Plus the Baofeng works on FRS and GMRS bands if you know how to set it up... not that you're supposed to, but its "good to know" info.
Congrats on your ticket. You can use an external antenna, like a mag mount on the truck with a short sma female to SO-239 socket adapter cable on the inside end to attach the Baofeng to the antenna coax which is usually a PL-239. I know some guys who run this but it doesn't sound as clear and noise free as my mobile and drops out when they hit low areas. We rag-chew nearly every day during drive time. 73
Thanks for all of the great info guys. I will probably be ordering tonight or tomorrow at the latest. I would love to have a dedicated mobile setup but I don't really want to invest a lot of money yet until I get more into it. Plus I need to get some of my buddies on board so I can have someone to chat with.
Dual band mobile setup seem to all be moderately expensive, dual VFO type units. But if you only need 2 meter, you can get a mobile unit for around $130-$150. It is definitely more expensive than a UV-5R, but it just seems like a cleaner installation. If you keep the UV-5R as-is and just throw it in your cup holder thats one thing, but if you try to add an external roof-mount antenna then it becomes more cumbersome to use the HT as the hand set. So you buy a mic, and mounting kit to put the HT in one spot. At that point, you're still ahead on cost, but it just seems clunky to me at that point.
Geof
The problem with using a uv5r or any portable for that matter as your first radio, is for most people who don't live real close to the repeaters, you're not going to be able to put a respectable signal into a repeater if you can even hit any repeaters.
I know you want to see what you're getting into before spending any more money but here's how this plays out with 90% of the new hams who pick a portable radio as their first radio. They listen and can't hear :censor:. They transmit and can't hit :censor:. They say "oh well, that was fun", put the radio away in a drawer and never turn it on again.
Since I am the first contact for many new hams using Baofengs, I can tell you that's exactly what happens most of the time. They're covered in noise, barely readable. I welcome them to the hobby. Tell them to get a mobile and a real antenna and that's the last anyone ever hears from them.
And with most things there is a right way and a :censor: way to do things. Mag mounts and cigarette lighter plugs are the latter. In a pinch, maybe but you don't want to go using that for day to day use. These are all new ham mistakes that you're welcome to try and learn yourself. Your $30 spent on the baofeng would be better put to use buying a mobile and a decent antenna installed properly. If you can't resist then just bear in mind your results will be a lot different using the right gear.
welcome to the hobby
Well I pulled the trigger on some new communications gear. Decided to get a CB as well as a Handie Talkie so I can monitor the trucker frequency's and buddies without HAM as well as start testing the waters of the HAM radio. Here's what I've got.
CB will be a Uniden 520XL mounted in current ashtray spot and routed to a TRAM 3500 mag mount that I plan on putting to the center of the roof.
Radio will be the Baofeng UV-5r with the upgraded Nagoya antenna. No plans for an external mount antenna at this time. I will have $40 invested in this thing by the time it arrives at my door and I want to play with it for a while to see what I think. The locals tell me they regularly get out 70 miles on repeater with one of these.
Someday if enough of my buddies get there ticket I may decide on a dedicated mobile setup. I figured the handie talkie will still be nice to have when out on the trails or camping.
A lot of times people think they're getting into a repeater because they can key it up and hear it come back to them but that doesn't mean they are actually putting a workable signal into it. That's precisely the problem. New baofeng hams think they're getting in but they are total noise.
If it was realistic to get 70 miles out of a $30 radio, EVERYONE would have one. Local governments wouldn't be spending 10's of millions of dollars on digital trunking systems, they'd all be using baofengs.
It's what makes it all work that matters.
Portables are nice for when you're on the trails and camping but when you're not on the trails or camping and you're in a suburban or urban environment and larger distances to cover and you want to talk to someone from your house or your car, well that's when you see that a portable isn't of any use without the right infrastructure in the right place. In building and in vehicle portable coverage on the ham bands is rare and becoming even more rare as good repeater sites become harder and more expensive to come by.
Well I would hope the guys from the local HAM club know what they are talking about. The group that I was talking to after my test had been at it since the 70's. If not then I guess I will be figuring out HAM just like I figured out how to swim and fix cars, the hard way !
I think we also have to remember what the intended use of this radio is. I have not yet gotten my ticket but plan to at the next HAMcram. I will more than likely pick up one of these small units with the upgraded antenna as it will STRICTLY be used for when I am on a trail run and communicating with my groups or the off chance that I need to contact someone while I am out and about looking for fishing spots. For $40 I do not plan for it to be able to extend to people while I am inside my house as you are correct ih88hi10 that the govt and everyone and their mother would have one.
I think for the intended use of strictly a trail run communications items and short distance expedition emergency communications this would fit the bill if someone wants low budget.
Half K--Welcome to Ham radio. And congrats on doing it right-getting your license and buying your radio. It's a perfect fit for an offroader. It will allow you good coms at a distance. Just for reference, I talk using my UV5 on a repeater that is 90 miles away, not bad for the 4.5 watts this cheap little radio can manage. For trail coms, 5 watts will be PLENTY.
Even the Baofeng is fine. It's better than no radio to get you started, though I fully agree that a good single band mounted mobile would be a better choice.
The antenna will make the biggest difference. A vehicle mounted high gain antenna is your best bet. Post number 3 is non-sense. There is no downside to a high gain antenna with this radio. The receiver will work better and the transmitter will transmit better. Log into a few local radio nets (often 7 or 8 pm on a designated night of the week) introduce yourself and get familiar with operating your radio. Most of the time guys are happy to talk to you on the radio, especially if you identify yourself as new operator and need some help with signal strength and radio operation.
To optimize your set-up you'll need the battery eliminator, and I'd mount a better antenna on the roof of your truck. And then I'd start saving for a real radio. One of these two:
Kenwood TM-281A
Yeasu 2900
Neither is very expensive, both are pro grade excellent bomb proof radios.
Take your CB and throw it in the bushes. Really, they are frustrating garbage and not worth your time.
That's an unrealistic claim and one that I have a hard time believing unless you've got a band opening. Which repeater? Where is it?
I'm not baofeng bashing here. It's also unrealistic for a $6800 Motorola APX-7000xe
It's also unrealistic for a mobile.
You callin' me a liar Roscoe?
Well stop by!
The repeater is K6POU, the one on the top of Mount Diablo in the bay area-145.330. It is almost exactly 90 air miles from my house in Sacramento.
The conditions are just about perfect-line of sight but still, it's 90 miles. Really this is not difficult at all. On the mobile radios with better antennas, it's full quieting into the repeater on 10 watts. With the Beofang it's scratchy, not surprising.
People get all hung up on power settings and the like when really the issue is antenna quality. If you have particularly good conditions, it doesn't take a lot of power. My best 5 Watt 2m simplex contact was from the Henry Mountains in Utah talking to a friend in Mexican Hat-he was 120 miles away.
I'm not saying these are great radios, they are OK radios at a great price. I have 2 of them and use them as loaners.
Really? :meh:
I have tried, this week, to talk to a guy across the bay, about 9 miles. I could literally see the building he was in and he had a rooftop antenna. Almost zero signal reception. I heard one syllable, kinda.
This is with the Diamond antenna on 2m.
Really? :meh:
That's an odd one Ed. Can he hear you?
I do have an upgraded antenna on my UV5R, but it's still just a hand held.
Cruiserdrew, thank you for the helpful reply. I will do some research on those mobile setups you recommend and keep them in mind for when/if I decide to upgrade. The local club is putting on an Extra class in January, four Saturdays of the month. I'm thinking about taking it in order to boost my knowledge of the subject.
The price point of the UV5 series have led to about a dozen ham licenses in our local club. We are gradually shifting away from that CB nonsense. They are fantastic for the trail, and the 2 I own have no trouble getting out to repeaters, sometimes local, sometimes not so local. I never changed the antenna.
I have a decent 2m mobile setup in my truck, but I don't go anywhere without these little HTs. Great for spotters on the trail, or just sitting around back at camp chatting with the guys still in the woods.
The only time I had tx/rx issues was when I was way down in a valley trying to get out to repeater. My Kenwood has the power and a well set up antenna to reach out and touch someone in that situation.
I can honestly say that everyone in our group loves these things. They are durable and have great battery life. IMO there is no downside to owning at least one.
Well stop by!
So what you're saying is "results not typical". You need clear line of sight and a low noise floor (VHF nowadays is pretty noisy) and I've heard of some contacts like that (not quite 90 miles), in the high desert, with nothing in between but a valley. Those really are the perfect conditions but most of the country doesn't have those conditions and many new hams don't care to find out what the fine print is and why that may work when they're outdoors on top of a mountain in the desert but not when they're driving around suburbia in their Faraday cage on wheels.
In the case of many new hams, they buy these radios because like the op, they can't afford to do any better but they'd be $30 or $40 closer to getting "better" had they not blown it on something they will get very little day-to-day use out of. And making wild claims of 90 and 125 mile contacts doesn't help do anything but put unrealistic expectations in the mind of new hams. You posts kinda read like a bubblepack of FRS radios promising "33 mile range!"
Why? Because like the OP of this thread, they want to "try it out" before spending any more money than they have to. That's like trying out offroading with a Chevy Aveo, a stock one at that, then getting stuck 2 seconds after turning off the pavement. The money spent on that car could have gone towards the right equipment and unfortunately the new hams don't learn why a Chevy Aveo is not a good choice for offroading, their expectations about Chevy Aveos were set so unrealistically high because someone in the Bonneville Salt Flats said they drove for a hundred miles offroad with one, and when they try to do that somewhere with mud and get stuck, they just give up.
I am not exaggerating when I say that there has been about a half dozen in just the past year who get those, I am their first contact or the second contact, they all say they don't want to install mobiles in their car or at home. They think it's going to work like a cell phone and get portable in building and in vehicle coverage wherever they go. That is just not realistic. And like they always do, they don't want to put any effort into it and that's the last anyone ever hears from them.
Really? :meh:
There is a high noise floor on VHF, it's a crappy band for use in urban areas and the vhf antennas on portables are highly inefficient. Try again, this time on 440 and let us know if you get a different result.
Yeah but it's sort of a double-edged sword.
The ChiCom radios may be affordable but when people have unrealistic expectations about what they will be able to do with them such as drive around in their car with one and still put a usable signal into a repeater...which is what this very thread is about, a lot of them are unsuccessful at making contacts and they hang it up and often do not bother changing anything to try to get a different result.
The other problem with the proliferation of Baofengs is we are seeing an unbelievable amount of unauthorized transmissions, jamming, malicious interference and the like. You can tell they're using the baofengs with those stupid noise makers they do.
And it's not just on the ham bands. We've had them go into LMR and do that crap, especially with mall security.
I'm not trying to broadbrush every baofeng owner as a lid or jammer. I'm just pointing out the downside, not that it's really relevant to the discussion at hand.
To balance it out, I have heard the uvb82 is a huge improvement in quality.
A dualband portable is a great tool to have when hiking. I always like to have a vhf portable just in case and also like to cross band using the a mobile in the truck and usually set that up to transmit on a vhf repeater. That requires a uhf radio. Having both in the same unit saves weight.
