Anyone replace this arm? (Rear KDSS)
San Diego
Website
youtube.com
Hey All
I searched couldn’t find any mention of it
Anyone replace this arm? Pic is a generic aftermarket piece, but only pic I could find with the stud exposed.
Mine seems to have a ton of slop in it and I think that’s the slight clunk I’ve been chasing.
Seems like it might be a tapered/pressed fit into the rear sway bar??
I figure those other bushings are probably toast as were all the others.
Thoughts?
Thanks
I haven't seen anyone replace it, but that doesn't mean it isn't necessary. It isn't exactly cheap, but isn't horrible either.
That fitting isn't taper, it just goes through and a nut tightens on the other side of the sway bar end.
The bushings are available separately.. I bought them long ago due to cracking in mine but never got around to pressing everything.. the shape of the arm seems tough to stabilize in a press. It seems the ball joint isn't available separately.
For the record..
Whole arm: 48830-60050
Middle bushing: 48849-60050
End bushing: 48849-60090
For the record..
Thank you sir.
Ordered the whole arm since the ball joint is what seems to have all the slop. At the angle it sits at, that has to take a ton of abuse, and its fairly small.
$238 at Olathe
I’ll report back when I get it all apart.
